Old 03-15-2010, 02:27 AM
apullin is on a distinguished road
Lathe advice; Taig or Harbor Freight?
Hey folks. I'm sure you've heard this question a million times; I'm slowly reading through all the old posts to get the popular opinions, but I'll ask anyhow:
I'd like to buy a small lathe for small/hobby parts. I'll definitely be doing a CNC conversion to it, since I have a spare (ancient) DeskCNC controller board.
My real question is, are the HF 7x12 machines total junk? If so, is it worth getting the Taig for the reduced feature set?
I'd likely be using the headstock riser block on the Taig, trying to do the CNC carriage drive through the power-feed screw, and replacing the spindle motor with a more powerful brushless one.
Old 03-16-2010, 02:34 PM
knudsen's Avatar
knudsen is on a distinguished road
Check the benchtop machines forums, they cover both Taigs and Chinteck
Old 03-18-2010, 08:40 PM
jrrdw's Avatar
jrrdw is on a distinguished road
I have the Harbor Freight (Central Machinary) 8X12 and it's completely manual so a conversion to it would be easy I think. It has turned out to be a nice little lathe. On a scale of 1-10, I give it a 7.75.
The only cons are the drive belt from the motor to the 1st pulley set is toothed. The head stock doesn't swivel and on my machine the head stock is about .0001 below the tool bit center so I grind the cutting bit to adjust.
Make sure you clean my wrench before you put it back into my toolbox.
HELP- HARBOR FREIGHT 8X12 LATHE ADVICE sunnyday Mini Lathe 25 10-23-2009 11:40 AM
DRO for Harbor Freight 47158 based on Harbor Freight 93293 Calipers Temtu Benchtop Machines 20 05-26-2009 10:29 PM
Harbor Freight 46951 Lathe? Larry N Mini Lathe 1 12-26-2008 06:46 PM
Harbor Freight 9 x 20 lathe jroma1 Mini Lathe 3 01-23-2008 05:23 PM
Harbor Freight 9 x 20 Lathe jroma1 Mini Lathe 6 01-10-2008 09:32 PM
