Old 03-09-2010, 10:09 AM
integrex585 is on a distinguished road
lathe worm gear cutting
have any of you guys ever put together a macro that would allow you to cut a worm gear on the od of a shaft. i want to feed in with a Y/Z move and go to a Z/C move for the length of the shaft and then feed off in another Y/Z move. i would like to put variables in for lead, number of starts, depth of cut, number of cuts, and start diameter.
if you have any ideas, or know of a source for this type of program drop me a line.
Old 03-09-2010, 01:14 PM
Can you tilt the axis of the milling cutter spindle? You will have to compensate for the lead angle of the worm helix somehow. You can see I ASSumed this is a live tooling application.
Dick Z
DZASTR
Old 03-09-2010, 01:19 PM
underthetire is on a distinguished road
Dick Z
Me to, since he wants to move Y axis.
Need some help finding worm gear oil Dustin L Linear and Rotary Motion 0 11-04-2008 02:32 PM
Need A Quote- Worm gear and worm drive LEWENZ Employment Opportunity 3 04-27-2008 04:28 PM
Need Help!- Worm Gear jackson General Metalwork Discussion 1 02-07-2008 03:25 PM
worm gear drive csrc DIY-CNC Router Table Machines 5 07-03-2007 02:53 PM
Ha5c Worm Gear engine tech art Haas Mills 8 05-09-2007 08:08 PM
