Old 02-27-2010, 05:43 AM
dgalaxy is on a distinguished road
what size arbor press
Hi im looking to buy an arbor press what size should i get im looking to broach some pulleys with up to maybe 1/8 inch slot do you guys think i could get by with a 3ton press i have no idea wich one to get the 5 tons are kinda out of my price range but the 3 ton is in grasp just thought somebody could put there thoughts in on this
John
Old 03-05-2010, 10:47 AM
Cory is on a distinguished road
What material are you broaching? A 3 ton press should work just fine for 1/8" keyways. We use a 5T for up to 1/2" hex broaches in 4140/4340 and it works well. We used to have a smaller 2 or 3 ton press that would broach keyways with no trouble.
Old 03-05-2010, 11:02 AM
it would just be in steel and aluminum i was just wondering i didnt want to buy a 3 ton and then it be useless for me. i just want to broach some pulleys and a couple of sprockets . so for small pulleys and sprockets i would be happy with a 3 ton you think
John
Press Beam size nicko17 Bending, Forging,Extrusion... 6 02-07-2010 01:43 AM
Build Thread- What Can You Do With A Arbor Press? captainlee Mini Lathe 0 03-03-2008 05:08 PM
PRESS Size? ZipSnipe Diemaking and Diecutting 18 12-07-2006 08:52 PM
Press fit bearing hole size? Loading General Metalwork Discussion 84 09-03-2006 04:36 AM
arbor press pressure MBG General Metalwork Discussion 2 04-01-2005 06:26 AM
