Old 02-26-2010, 08:50 PM
wyobmf is on a distinguished road
1998 Hitachi Seki VM-40 MX-3 help? Will Pay.
Hello,
Bought this machine for a decent price, powered it up and it had a servo drive erorr so I changed out the drive it powered up with no errors and worked fine.
Untill I tried to do a tool change throught the MDI and the tool arm rotated without releasing the lock pin first and broke the arm. It is fixed again and I am looking for someone to help me out, With getting the ATC to work, I will pay for phone/e-mail support. I have the manual and I am knowledgable on the electonics and mechanical part of CNC machines, Just never did the machine setup part. I am not sure anything is broke just not sure. I think there is a macro in the controller that does the tool change and there is a way to manully step throught the ATC.
Old 04-09-2010, 10:42 AM
Dancy's Avatar
Dancy is on a distinguished road
Yes, M-codes
In the MDI
and
“maint” mode (toggle switch inside cabnet)
M100 Arm swing in to spindle
M101 Arm slide to spindle
M102 Arm advance
M103 Arm Turn Clock wise
M104 Arm Turn CCW
M105 Arm Retract
M106 Arm slide to home position
M107 Arm swing/return
M108 Arm slide to Magazine side
M119 Orient spindle
so sequence is
M119
M100
M101 at this position you can adjust the arm to fit your spindle
tool clamp/unclamp Manual push button
M102 at this position you can adjust the arm to fit your spindle
M103/104
M105 at this position you can adjust the arm to fit your spindle
M106
M107
Dan Clemens
Summerville, Ore
Old 04-09-2010, 10:52 AM
307startup is on a distinguished road
Where are you located? I'm in Casper, if you still need the help.
Originally Posted by wyobmf View Post
Hello,
Newbie- Post Processor for Hitachi Seki Lathe astro cnc Mastercam 1 02-11-2009 07:20 AM
Need Help!- Hitachi seki fanuc o-t comtrol yukon517 Fanuc 2 10-14-2008 07:23 AM
Mori Seki - Fanuc 11T brourke General CNC (Mill and Lathe) Control Software (NC) 9 07-25-2008 08:42 AM
Mori Seki Sl-15 Machine Parameters MILLMANM General CNC (Mill and Lathe) Control Software (NC) 1 10-24-2007 07:36 PM
Mori Seki SL4 programmer1956 Mazak, Mitsubishi, Mazatrol 3 03-08-2007 04:22 PM
