Old 02-25-2010, 06:32 PM
cncwhiz is on a distinguished road
What is this machine?
A friend of mine sent me these pictures of a machine that he needs build programs for. The machine programs like a lathe for the most part with some g and m codes that are for this machine. Has anyone seen this machine before and know anything about it?
ID:	100768   Click image for larger version
ID:	100769   Click image for larger version
ID:	100770   Click image for larger version
Old 02-25-2010, 07:36 PM
bluelion2618 is on a distinguished road
No, I don't know that machine. I know CNC Router with 3-axis well.
Old 02-25-2010, 09:47 PM
Horizontal Machining Center with auxiliary CNC boring/facing head????
Dick Z
DZASTR
Old 02-26-2010, 11:31 AM
packrat is on a distinguished road
The yellow part being held in the fixture (second photo from left) is a "pipe wye" a plumbing connection. Is this possibly to thread the pipe connections?
Old 03-01-2010, 06:39 PM
That part looks like a mold "core" to me. I have never seen a machine like this one and I have been in the business for over 30 years. I know that the machine is made in the UK and it programs like a lathe?
Old 03-02-2010, 12:42 AM
BruBeck is on a distinguished road
I believe this is a boring machine. The head can be controlled in-out (depth) and traverse (diameter). The table looks like it is index-able with offset control. The head is fitted with an boring bar to machine an O.D.
That would be three axis control plus the spindle and index... I think.
Old 03-02-2010, 10:14 AM
I believe that you are correct. I would like to find the "usable" code that runs this machine. It seems like it should be very simple to run if you know the codes it need to run...
Old 03-02-2010, 11:04 AM
I have found that most tool builders use a generic control from say Dynapath, Fanuc, etc and reconfigure it using the vendors development kit. A mill or lathe is usually configured to EIA RS274 standard making them sort of easy to figure out. A machine like yours will probably use a lot of standard codes for obvious things, but something like traversing the boring bar to face off a workpiece might be a custom canned cycle (or not). Canned cycles are your biggest problem because of the variables that must be passed are really hard to guess even if you figure out the G code.
System parameters available on some controls may tell you how a canned cycle is configured, GE2000 comes to mind. Sometimes these parameters are password protected though.
The control mfg will probably not be able to help you because of the customization done by the tool builder.
I know this isn't very helpful but good luck!
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Another machine rigid tapping (stepper machine) samco LinuxCNC (formerly EMC2) 10 04-10-2009 07:21 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
