Results 1 to 4 of 4
Thread: where to find a cnc 4th axis table "servo"??
    Apr 2005
    us
    its for a plm 2000. the machine is dos based and has an anamatics 4 axis controller. I dont want to spend a fortune. a saw a sherline? any comments on this would be appreciated
    Feb 2004
    hh
    build one
    I did
    Gold Member
    Jun 2003
    I saw someone using this over at cnctoolkit yahoo group, he said it was a zero backlash 1:100 harmonic drive.
    http://www.surpluscenter.com/item.as...-1416&catname=
    http://www.surpluscenter.com/item.as...-1519&catname=
    Some were also using these for 5 axis gantrys, these are out of stock.
    The verticle mount gear motor has a servo on it, you probably just need to put an encoder on it, otherwize you could change it out for a different one.
    I have a h/v rotary table from littlemachineshop that I havent quite gotten on my mill but converted and am almost there.
    Jon
    Jan 2005
    Missouri
    I ended up with one of those vertical mount gear motors (new) in a crate of surplus "junk" that I had bought. I checked with Amtek regarding the motor, it is rated at 583 oz./in. of torque, making the final output a whopping 344 lb./ft. of torque at 99 volts D.C. Now mine has an encoder on the motor shaft. In the crate of stuff that the motor was in, were items that looked like that they were from some kind of robotic mail server cart and this was the drive motor. Now if I just had a use for it.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
  1. 4th Axis for Fadal 4020
    By Fudd in forum Fadal
    Last Post: 07-23-2012, 04:49 PM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-13-2005, 10:08 PM
  3. 4th Axis
    By UKRobotics in forum General Metal Working Machines
    Last Post: 03-19-2005, 10:25 AM
  4. 4th axis cnc
    By Mbair in forum General Metal Working Machines
    Last Post: 01-17-2005, 07:27 AM
  5. Cost / Price of a DIY CNC table.
    By Havic in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 03:08 PM
