| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Hello everyone I just wanted to ask anyone who can help me out and tell me the difference in machining 7000 series aluminium and 6000 series. Job is 7000 series material 3000mm x 2000 x 90mm thick Heve to cut a profile with a 50mm cutter hoping for 10mm depth of cut. Does 7000 series machine different to 6000 series Is it easier or harder to machine. If you have any suggestions please e-mail me kosta@ncprecisiontooling.com Thanks guys Kosta |
| Hey Kosta, 7 series is much harder than 6 series and more difficult to machine - to a certain point. The thing is that it's so hard (for aluminum) that chips don't generally stick to the endmill like 6 would. You can check out the specs, might answer your questions. BTW, that site has an amazing amount of information on different metals and alloys - it's got a buttom on my browser so I have it for quick reference. JR |
| The 7000 series is a higher strength alloy than the 6000 series and contains larger amounts of zinc & magnesium. In general, aluminum such as 7075-t6 does not require heat treating after welding. The 7000 series is a little tougher to machine compared to 6000 and tends to be more free machining. It is not as ductile. When machining any aluminum you do not want the chips to stick to the endmill. If you have a problem with that it could be feerates too slow, rpm too fast, wrong number of flutes (too many) when slotting/pocketing (chips not evacuating), depth of cut too deep, or lack of lubrication/coolant. 7000 series corrodes more easily than 6000 and will discolor quickly when using synthetic coolants. |
