| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Hi, We are working on a cylinder that has a deep step bore (sketch attached). Please take a look at the aketch and advice on the following:[*]Can this item be best made on a VMC or a Turning Center (we do not have a gun-drill)?[*]What is the process that you suggest we follow?[*]What are the tools that you recommend we use?[*]How can the specified surface finish of Ra 0.6 be achieved? Any advice on the above will be highly appreciated. Thanks! Prasad |
| You could drill & bore undersized then finish with a Mapal or Cogsdill reamer. That would provide good size control. These reamers also have pads on them that burnish the surface to a smooth finish. Depends on how malleable the material is. Dick Z
__________________ DZASTR |
| Hello Dick, Thanks for your advice! Will get in touch with Mapal/Cogsdill for their reamers Just FYI - We tried drilling + bore lapping but didn't work. As for burnishing, we were told that the l/d ratio was too high for a regular burnishing tool |
| Tags |
| deep bore finishing |
| Seeking advice on GE/Fuji AF-300 VFD | jimjovan | Phase Converters and VFD | 2 | 04-04-2010 08:21 PM |
| Prospective Machinist Seeking Advice | Septimius | CNCzone Club House | 8 | 02-26-2010 12:57 PM |
| SEEKING ADVICE | kling8 | WoodWorking | 3 | 11-19-2009 02:19 AM |
| Need Help!- Macro Programming for Taper Bore machining | yaji63 | G-Code Programing | 30 | 05-21-2008 10:26 PM |
| Can an X1 bore a deep 70mm dia hole in Al? | digits | Benchtop Machines | 59 | 03-04-2007 09:24 AM |
