Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 11-27-2009, 04:39 AM
jenx is on a distinguished road
help with speeds & feed
hi everyone, i am running a cnc miller cutting aluminium 6082. what would be the best speeds and feeds for finishing cuts using a solid carbide 8mm ball nose at approx .1mm cuts
m/c spec
12000 max rpm
feedrate 12700 mm/min max
plus any info regarding better cutters to use for finishing ops using the same m/c
at the moment my finish is not the best and its time consuming
been out of the game for 4yrs, not machined much alli in the past!! any help would be much appreciated
many thanks
Old 11-27-2009, 10:25 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Since its a ballnose with only 0.1mm DOC, you have a different effective diameter than 8mm. The diameter at that DOC is only about 1.8mm.
I make that as a 12000 rpm and maybe 300-340 mm/min feedrate using G-Wizard. You may be able to get more feed, but experiment to see what the finish looks like.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
feed override and rapid speeds rkremser Mach Mill 1 02-03-2009 08:04 AM
Need Help!- 2 speeds plunge feed? Claude Boudreau BobCad-Cam 4 05-08-2008 04:48 PM
Ignoring Feed Speeds xichanceix DeskCNC Controller Board 1 12-17-2007 08:55 PM
Calculating feed rates and speeds for ABS d11rdozer Glass, Plastic and Stone 0 09-12-2007 05:46 PM
General Feed and Speeds? BulleTxMagneT General CAM Discussion 1 08-18-2007 02:41 AM
