Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 10-29-2009, 03:53 AM
jeuhrn is on a distinguished road
0.2mm fullcarbide Fraisa mill in AISI 316
I'm trying to cut some grooves in 316 with a Fraisa 0.2mm endmill (2 flutes).
The catalog only makes recommendations for hardened tool steels 42-60 HRC.
With a gear I have capabilities for up to 40 000 rpm, but my test so far has been with:
30 000 rpm, ap 0.02mm, 250 mm/min feed.
The mill snapped at the first pass.
It's not a diving mill so I'm diving into 0.5mm holes.
Anybody have any experience with this?
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
Need Help!- Drilling in W.EN 1.4980 /AISI 660 praest General Metal Working Machines 3 04-10-2008 07:09 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 07:56 PM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 11:15 AM
