I needed to turn some small parts, but I don't have a lathe. So i came up with this idea.
The video is a 1" peice of 4140 steel being turned on my CNC knee mill. The material was held in a 1" end mill holder, R8 collets work even better, and the turning tool was clamped in a 6" vise. One can program it just like a normal lathe this way.
Video of MILLTURNING You will need windows media player to watch the video 518kb.
700 RPM
3 IPM feed
.03 DOC
This turning method should work well up to about 5"-6" OD, and 4"-5" long material, on a good knee mill. If your quill is loose/sloppy, you will probably get chatter. If you have a manual knee mill, or loose quill, I would reccomend using the knee as the Z axis, and leave the quill fully retracted and locked for rigidity.
Of course you could just buy a lathe, but I spent all my money on the mill :frown:
If anyone knows where you can purchase a 3" or 4" three jaw lathe chuck, with an R8 shank, let me know, otherwise I am going to have to make an adapter myself out of a boring bar adapter or possibly a shell mill holder.
