Results 1 to 4 of 4
Thread: Have a foam question.
    Oct 2004
    I'm looking for foam with the same consistancy as say a mouse pad. Can this type of foam be easily machined? If so what is it called and where can I get it? Or would it be easier to make some molds and cast it?
    Thanks,
    Ryan
    May 2004
    As far as I know mouse pads (the foamy ones) use a cheap grade Neoprene. A more expensive version of Neoprene is used in diving wetsuits. Neoprene is normally die cut but can also be cut with a vinyl cutter (the heavy duty table top type used to cut the heavy grade reflective vinyl for roadmarking signs, not the cheap see-saw roller type). Regarding machining it, you'd have to be a bit more specific as to want you want to do with it before anyone can answer that. i.e. product how big? what does it have to do (without giving away what exactly you're doing if it's commercially sensitive)? what type of machining: mill, router, lathe? I know PU can be moulded using a foam mix and it's DIYable. (bet that word isn't in the dictionary)
    Skippy
    Oct 2004
    I'm looking to make something similar to this:
    It's part of a seat pad for a motorcycle. What I was wanting to do was maintain the same shape, but have it say RC51 in the center of it. I'll also be using a Sherline 5400 mill.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Neat lookin' seat! Sorry can't help on your foam question - but I'll add another, if I may. How about visco-elastic foam? You know - like the Tempur-pediac mattress. Anyone know of a good (available/cheap/etc) source? If you could get it in thin enough form, maybe glue/affix to a firmer machined foam underneath?
    cheers - Jim
    wireless from s/y Laughing Buddha - BOI, NZ
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. Junk foam CNC?
    By ls7corvete in forum DIY CNC Router Table Machines
    Last Post: 03-15-2007, 11:29 AM
  2. Bobcad wire EDM for foam
    By onthemarc in forum BobCad-Cam
    Last Post: 07-18-2005, 10:13 PM
  3. Extremely basic machining question.
    By touser in forum General Metalwork Discussion
    Last Post: 06-19-2005, 01:51 AM
  4. one piece foam cutter
    By bladestalker in forum CNC Wire Foam Cutter Machines
    Last Post: 06-08-2005, 07:36 PM
  5. Expanding foam beads
    By TinkerDJ in forum Moldmaking
    Last Post: 04-29-2005, 02:48 AM
