Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-18-2009, 09:46 PM
*Registered User*
xmaldinix is on a distinguished road
a36 material
can somebody tell me what inserts are good to machine a36 material.
thank you.
Old 06-20-2009, 08:10 AM
PixMan is on a distinguished road
Turning or milling? If turning, what holders do you have? If milling, what cutters do you have? Most commonly, it's a bar, sheet or billet for milling.
So, what operation do you have to do? Are you needing to mill big surface areas or small features? A good steel milling insert works great as A36 is a fairly mild, easy-machining type.
Old 06-20-2009, 09:50 AM
Med-Pac is on a distinguished road
carbide should work fine, hope that helps ya
Mike
Old 06-20-2009, 12:03 PM
When I wrote "A good steel milling insert works great", I of course meant a carbide insert FOR steel.
For instance, if you're doing heavy roughing on a "50 taper" machine, the new Valenite V560 mill is really hard to beat. Up to .400" depth of cut, it's 10-sided inserts can handle upwards of 700sfm and .020 inches per tooth in A36. That's a lot of horsepower required, but metal removal rates through the roof. With a big enough cutter and big spindle HP, you could fill a pickup truck bed with chips before lunch!
So...is the OP doing roughing, finishing, or both? What machine? What tool holding system?
Where do you buy material? justgary Want To Buy...Need help! 4 04-21-2009 10:17 AM
What material is better 304 or 303 Joseph Souza General Material Machining Solutions 5 08-06-2007 05:26 PM
Material??? Grass-hopper JGRO Router Table Design 1 01-25-2007 06:21 PM
Where to get raw material? ormandj General Metal Working Machines 10 08-11-2006 09:20 PM
Material ryanduc General Material Machining Solutions 0 01-29-2005 06:50 PM
