Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 05-18-2009, 08:04 AM
gepperta is on a distinguished road
Milling Inconel welded parts
I need help with up to date suggestions for milling reconditioned gas turbine parts that have been welded with Inconel. I do not have the exact alloy name. I remember years ago we would take as deep a cut as possible because of work hardening and go very slow otherwise. I also remember using a sulphur free cutting oil that had the consisitency of honey, but I can't remember the name.
Old 05-25-2009, 07:06 PM
PixMan is on a distinguished road
Valenite has a new grade of carbide insert for milling high-temp alloys. I've had good luck with their PDMX 0905ZEER51 grade VP2003 inserts on their V556 high-feed mill. It's not depth of cut that keeps the material from work-hardening, it's staying in the feed. NO DWELLS!
I'm running 200 sfm in Inco 718 @ 42Rc. Though it's a shallow depth of cut (.060), it's feeding at .024 inches per tooth. Gets the job done quick! There are ceramic grades that work well too, so I hear, but I'm afraid to apply the speeds they specify for fear of changing the temper of the workpiece. I can't imagine what a shower of sparks would do to the workpiece (or the cutter for that matter.)
Old 05-26-2009, 11:07 AM
Thanks for the help. I called Kennametal and spoke with them about 1/2 dia
whisker reinforced ceramic inserts, grade KY4300. They suggest 870 SFM and then watch the fireworks. My problem is milling small air foil shaped pockets, so he recommended solid carbide end mills grade KC 635 at 100-200 sfm and .0002-.003 fpt.
.024 fpt is quite aggressive. How does the finish look when you are done?
Old 05-26-2009, 04:41 PM
USMCPOP is on a distinguished road
My son TIG welded gas powerplant turbine blades for awhile at Alstom. The base blades were Inconel 738 and were built up using Inconel 625 filler.
Old 05-29-2009, 04:37 PM
Parts look stunning if you add a wiper insert or two. Otherwise, between a 125 and 250 microinch finish.
The low depth-of-cut is easy on the workpiece while the high feed rate moves the heat off with the chips. This method is what many mold shops have turned to for faster removal of cavities. I don't know the configuration of your parts, so "Ask your doctor if high feed milling is right for you".
Old 07-29-2009, 01:43 AM
crabbass is on a distinguished road
watch the video on youtube. I think it was called High speed Machining Inconel 750. This looks like it is being ran in a pretty robust machine with a #50 taper.
My First All Welded Steel Router Design widgitmaster CNC Wood Router Project Log 9 10-18-2008 09:07 AM
hot welded parts in home insulation?? gorillam Safety Zone 3 08-13-2008 09:06 PM
Casting material to use for aluminum parts that end up being welded. KyleH2 Casting Metals 3 07-23-2008 02:43 PM
Heat treating A36 MIG welded frame ad_bfl Mechanical Calculations/Engineering Design 2 09-05-2006 02:07 PM
Anodizing Welded Aluminum Deviant General Metalwork Discussion 9 10-17-2005 09:23 AM
