Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 05-14-2009, 04:10 PM
hebrewhammer8 is on a distinguished road
Routing/drilling Alum. honeycomb
Need to route some .5" Aluminum Honeycomb and drill some blind holes in it.
Anyone have any exp. cutting the stuff?
What kind of tool for routing would all you masters recommend?
Also i need to drill some insert holes that need to be flat on the bottom, i was thinking about just using an endmill?
Sage advise always appreciated.
Z.
Old 05-15-2009, 07:26 PM
John Welden is on a distinguished road
Z.
Aluminum is going to be easier to cut than the graphite Glass/Phenolic honey comb that I've cut. Just used a normal carbide end mill and it cut fine.
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
cnc cut 1 inch alum? Todd W General Metalwork Discussion 4 04-29-2008 07:40 AM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
Benchtop PCB drilling/routing VentureElec Benchtop Machines 9 07-28-2006 02:38 AM
