Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 04-07-2009, 07:32 AM
Bryan GD is on a distinguished road
Heat Transfer Prop. of Pratley "Steel Quickset"
Hi
I have a 3W LED which is fixed onto a small, star-shaped Al plate.
I would like to fix the Al star plate to an Al heatsink, as it produces quite a lot of heat which must be removed.
Unfortunately I can't use screws and thermal paste.
I can't source thermal glue or thermal tape in time.
Can I use something like Pratley's "Steel Quickset" (epoxy) a.k.a "Set-Like-Steel" ?
Does anyone know what this product's heat transfer capabilities are?
Is this epoxy able to transfer heat sufficiently?
Temperatures +/- 35 deg C
Thanks!
B
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
Problem- "wrong program data" when file transfer???? spock Bridgeport and Hardinge Mills 2 07-28-2008 05:59 PM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
How to order 4.5"X4.5"X10' steel Shotout General Material Machining Solutions 9 10-02-2007 08:24 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
