Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-21-2009, 03:09 PM
MattRMD is on a distinguished road
Unhappy Helicoils
Anyone had any problems with Helicoils? I had about 86 Helicoils i dropped into an aluminum plate yesterday and when i went to place the screws in the helicoils kept binding on me. I followed all procedures and everything. It was terrible I spent all day working this plate and at the end of the day It was shot. Had to scrap the $160 dollar plate. Also, ended up busting 3 taps trying to get the helicoils to work?
Any Answers?
Thanks,
Matthew Yonekura (408)661-3732
Email: Matt.Yonekura@hotmail.com Research Machine Development Inc.
Old 03-21-2009, 03:26 PM
HuFlungDung's Avatar
Moderator
Was your helicoil tap in perfect condition? It is conceivable that if the tap was damaged and the resultant thread was malformed, that the helicoil would not seat correctly, thus reducing its minor diameter enough to cause interference on the fastener. Also, did you tap the hole deep enough so that you did not run the helicoil up onto the taper ramp formed at the bottom of the hole?
Old 03-23-2009, 09:46 PM
Smile Helicoils
Thats good advice but everything was done by the books. Company sent us another batch of helicoils for free so these should work. Thanks for the help!!!
