Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 01-12-2009, 05:11 PM
Billet Sean's Avatar
Billet Sean is on a distinguished road
Looking for a rubber, lol
I was hoping that someone could tell me what kind of rubber pencil erasers are made out of. I need to either purchase the raw material (in round stock) or the erasers themselves in bulk. The material doesn't have to be the same as the erasers, but it does need to have similar properties. I'm trying make some dummy bullets that I can dry fire in my weapon. So the material needs to absorb the impact of the firing pin hitting it A LOT without getting shreaded. Any help would be greatly appreciated!
Old 01-12-2009, 05:41 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Mcmaster carr has a great section on selecting the proper rubber for your application. And then a large selection of what you need.
Karl
Old 01-22-2009, 03:14 PM
Nick1983 is on a distinguished road
why not buy rubber stock at your desired thickness then have a local fabricator waterjet to the desired diameter.
Old 01-22-2009, 07:47 PM
We use to have a waterjet. We sold it a few years ago though. It's too expensive and there's only 2 shops around here that have them. And they charge an arm and a leg. Thanks for the input though. I appreciate it!
Old 01-22-2009, 09:07 PM
BYTHEBOOKBOB's Avatar
BYTHEBOOKBOB is on a distinguished road
I'd recommend urethane rod that is also available from McMaster Carr, Shore A, 60-70 durometer should do the trick. You can grind it or machine it as required.
Good luck,
Bythebookbob
Old 01-23-2009, 04:03 AM
Spanners is on a distinguished road
Or a piece of o-ring cut and fitted intot he primer pocket
Machining rubber HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 10 05-01-2011 03:59 PM
Rubber Bellows sprintfan DIY-CNC Router Table Machines 8 09-20-2009 10:54 PM
Waterjetting Rubber Miguel Gonzalez CNC Plasma and Waterjet Machines 3 06-18-2008 09:27 PM
Sponge Rubber and Diamond plate looking rubber? DennisCNC CNCzone Club House 1 06-01-2007 12:15 PM
Best rubber MBG General Metalwork Discussion 8 10-17-2005 09:27 AM
