| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
HI NEW TO THIS MY ? IS I AM TRYING TO MILL A .140 WIDE SLOT THRU .700 ROUND 6061 ALUM THE SLOT IS .200 LONG USING VMC W/O COOLANT THRU I AM PRE DRILLING EACH END THEN GOING IN WITH .125 ENDMILL ROUGHING OUT .06 DEEP WITH EACH PASS THEN PROFILING TO .140 WIDE ANY IDEAS I KEEP BREAKING ENDMILLS THANKS MERT |
After drilling the ends, I would "drill" the center of the slot with a .125 end mill. Then use plenty of coolant, and cut the profile with the end mill (.060 is a fine depth of cut). If not coolant, plenty of air. I would relieve the end mill (grind diameter a few thousandths smaller)! If your depth of cut is .06, all you really need as far as flute length is .06 (okay, a bit more than that, but...). Any extra flute length will likely bind, and cause chatter in the ends of your slot - not to mention if your tool is a bit worn at the cutting end, when the full-size shank reaches the slightly-undersize slot, it will rub a bit and then break. Hope this helps! |
| if your not using coolant you probably should if you have the ability(heh saw you said you dont have coolant thru)coolant thru is unimportant for what you are doing you just need to flush the chips out,otherwise take more cuts,yeah it will take a bit longer but you could up the rpm and feed quite a bit if you did it in say .020 deep passes. Also double check too make sure you are on centerline of the part. How are you holding the part? what brand VMC are you using and what feeds and speeds are you currently trying? more info the better. hope I was able too help. |
| Job Opening machinist | Tandem1 | Employment Opportunity | 0 | 07-08-2008 10:17 AM |
| Need Help!- old machinist | farmerq | General Metalwork Discussion | 14 | 04-27-2008 10:04 AM |
| Looking for CNC machinist/manual machinist in detroit metro area | Runner4404spd | Employment Opportunity | 4 | 11-12-2007 12:11 PM |
| wants CNC machinist | cindymuge | Employment Opportunity | 0 | 10-19-2006 01:58 PM |
| Need CNC machinist | CBNDude | Employment Opportunity | 0 | 06-03-2005 04:41 AM |
