| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
hi, I need to make some 3d milling of some halves plugs for some RC plane rudders. I would like to find a material which I can mill easilly and then mold with resin after waxing. I used to do that with MDF and then spraying primer but MDF is too hard to machine and noizy. don t like this solution. is there any economical alternative like filled resins blocks? the blocks need to be about 500x500x50mm |
| Oh, forgot to say, try to find som Ureol blocks and try. Very common material to make prototype and low volume casting moulds for alu parts. http://www.youtube.com/watch?v=dzirz...eature=related Last edited by svenakela; 08-19-2008 at 08:33 AM. Reason: Added movie link |
no the machine isn t too weak...maybe i didn t explained correctly. the machine can cut and even break my Kress 1050 if my 10mm mill blocks into it. the point is that the mill gets hot fast and the burn the mdf...if I reduce more the rpm, then it doesn t remove fast enough the material...I cut at a feed of 1000mm/min with 3mm depth. |
| Milling Black plastic blocks | joguy | Machinist Feedback | 6 | 11-20-2008 12:57 PM |
| end blocks | john86126 | Linear and Rotary Motion | 0 | 04-28-2008 08:57 PM |
| MDI ONLY 10 BLOCKS HELP!!!!!! | john-shipman@ho | 5T/5M | 1 | 12-25-2007 11:34 AM |
| RFQ for maple blocks | CNCadmin | Employment Opportunity | 8 | 04-10-2007 02:41 PM |
| Centering blocks | Hobbiest | DIY-CNC Router Table Machines | 4 | 02-09-2004 10:57 PM |
