Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-12-2008, 09:12 AM
Lugy is on a distinguished road
Help needed to machine DAP 5553
Hi all, I'm working on a job just now using DAP 5553. We are getting load's of problems with it chiiping. The workpiece is being held in a nest machined into a Chick Vice so is gripped all around and is also gripped as deep as possible.
We are using carbide slot drills, we started using around the same speed's and feed's as aluminium, then half those.
We have been trying all sort's of different approaches to machine the part, each time it would chip.
Does anyone have any experience with this material?
http://www.almoco.nl/dap5553.pdf
Cheers
What machine is needed...? TAftonomos Bending, Forging,Extrusion... 2 02-27-2008 09:49 PM
Newbie help, milling machine help needed tyrc racing General CNC (Mill and Lathe) Control Software (NC) 0 08-08-2006 04:50 AM
CNC Router for under 7k machine suggestions needed M4RK_23 General Metal Working Machines 3 01-10-2006 12:12 AM
Design help needed to finish off machine. Apples Mechanical Calculations/Engineering Design 0 11-26-2005 04:34 PM
Help needed in building a CNC machine aran.nav Stepper Motors and Drives 0 01-11-2005 06:40 PM
