Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 05-12-2008, 08:34 AM
marc.brunet.gag is on a distinguished road
Acrylic routing problem
Hello,
I'm working in a signs manufacture company and we are machining acrylic. Now the process is that we cut the acrylic with a CNC router, but the finish is not good so we need to sand it, after and we burn the edge to give a perfect transparent finish.
My objectif is to eliminate the sanding process because it is very long.
I tried several bits on the router to give a perfect finish, 1 flute, 2 flute, 3 flutes, spiral, straight, ... my main problem is that I don't know what RPM and feed to use to have a perfect finish and with with bit.
I want to make it in one pass.
Can you help me?
Thank you
Marc
Old 05-12-2008, 09:29 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I route a lot of polycarbonate as opposed to acrylic, but some things are similar I would think.
Acrylic does melt easier than poly.
The finish on my stuff is not crucial. I don't flame polish the edges, but have played with it.
I think one way to get a better finish is to actually use a finish pass. Just set that up on the Cam side. A very light high speed pass should yield pretty good results and reduce sanding at least.
Any slop at all in the machine or spindle will show in a single plunge pass, but if you do a finish pass, it's a high speed light cut and should easily produce a smoother edge.
Lee
Old 05-12-2008, 09:56 AM
beone is on a distinguished road
try painting dish washing soap on the plastic before cutting. improves the finish greatly
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Old 05-12-2008, 10:16 AM
elogicca is on a distinguished road
I use onsrud 2 flute downcut, great bits give a great finish 18,000rpm 160ipm 0.165doc.
But i do get some chatter on the edges, if an optical finish is needed you have to sand.
I imagine a 100% rigid machine would not leave tool marks on the work piece.
Old 05-12-2008, 10:17 AM
Imo I would not put any detergent near acrylic, if he was to put detergent then cut then flame he would get crazing.
Old 05-12-2008, 11:23 AM
SCRAPWOTSCRAP is on a distinguished road
What thickness acrylic??? Elogica is correct about the detergent....you don't need crazing at the flame polish stage. 14,000 rpm/180 in min creates less melt in the acrylic.......thus less sanding. A .020 finish pass at very high feedrate will reduce sanding dramatically.
Old 05-12-2008, 01:00 PM
Not necessarily, use a very mild detergent. I have machined a lot of acrylic using a water-detergent mix without any problems.
Don't use the uber powerful degreasing detergents, they may cause problems.
Old 05-12-2008, 02:44 PM
You'd be surprised what will react though when you get to flame polishing, even acrylic polishes respond bad to it.
Old 06-11-2008, 09:35 PM
rhundl is on a distinguished road
Why dont you try a buffer like you would use on a car... You still may need to sand it though... if you use a heavy enough polish it may yield the results you are looking for
Old 06-11-2008, 11:52 PM
cutsall is on a distinguished road
spray mister with minimal pure water has been most effective for me. air clears chips and water cools and eliminates weld back or frosty look to cut edge. have been able to get nice traslucent edge but for transparent still requiers polishing.
If it is true a person learns from their mistakes then I must be the smartest man alive.
  #11   Ban this user!
Old 06-12-2008, 12:26 AM
automizer's Avatar
automizer is on a distinguished road
i ran the router table for a sign shop for 3 years and i ran onsrud O flute cutters with a vegetable based oil mist and after some play you can get the speeds down to almost not need the flame
I'm not lazy..., I'm efficient!
HAAS GR-408
Cutting Acrylic Gujustud Glass, Plastic and Stone 20 01-27-2009 07:05 PM
Speed problem when routing a lot of small lines. Witsenburg Mach Mill 18 06-30-2007 02:19 PM
Acrylic blfuller123 DIY-CNC Router Table Machines 3 12-28-2006 08:15 AM
Acrylic Mike7 Vacuum forming, Thermoforming Etc 2 10-30-2006 10:16 AM
Anyone routing polycarbonate/acrylic? kong Machine Problems, Solutions , Wireless DNC, serial port 13 07-27-2003 01:40 PM
