Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-03-2008, 08:41 PM
umsilba is on a distinguished road
Talking Bone screws
Hello,
Did any body knows how to machine bone screws thread with single point insert in a CNC lathe?
Old 03-18-2008, 08:16 PM
PixMan is on a distinguished road
Not as nice & easy as thread whirling, but do-able. I've done it with G32 (Fanuc 16i-TB control) successfully. You'll have to get the screw profile ground into a custom insert, so I might recommend calling Etco Tool (Waltham MA) as they were my source for inserts that perfomed very ell in the 6AL-4V titanium alloy I had to cut.
You can do the first tapered section with a "R" value for the taper, then match the next straight section to it. Depending upon machine and control, it might use G33 or other codes to make thread section match up.
Old 05-12-2010, 05:55 AM
hrifai is on a distinguished road
Bending
I use same method, and even profile the inserts myself, but without a tailstock (my machine hasn't got any) there is a limitation as the screws bend
I hope I could be able to upgrade to whirling, but with these prices, I doubt.
Did anyone ever consider homemaking a thread whirling head ?
ball screws morbius Bridgeport and Hardinge Mills 2 06-05-2007 03:37 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
Take out screws vmax549 Bridgeport and Hardinge Mills 5 02-13-2006 10:22 AM
Why doesn't anyone use THK and NSK Rolled Screws? Noah General Metal Working Machines 9 07-19-2004 12:58 PM
What Screws To Use For Mdf? ljoe1969 DIY-CNC Router Table Machines 12 04-27-2004 05:28 AM
