Results 1 to 7 of 7
Thread: XPS warp issue after routering
    Jun 2007
    I am cutting extruded polystyrene on a CNC router. The foam is warping after removing the material on one side. I have done testing and taken off equal material off of both sides, but for this project re-machining the bottom after routing the top is not an option. These are large parts 4' x 4'.
    Any ideas or suggestions would be greatly appreciated.
    Paul
    Mar 2004
    Sweden
    How do you hold it down?
    What's the density?
    Jun 2007
    The foam is a 2lb density and we are holding it down with vacuum.
    Mar 2004
    Sweden
    Are you sure it doesn't compress by the vacuum?
    It can happen if it's not a closed cell.
    Jun 2007
    I am quite confident that the vacuum is not compressing or warping the material. I have tested this and cut of 25% of the total thickness of a sheet off one side and it warps significantly, flip the part, and take the same cut off the back and it straightens back out. Similar to metal. I never would have thought this would act in this manner. I dont want to buy oversize material and machine both sides if I dont have to. Other than flipping the part to re-flatten the bottom, all of the machining is done from one side only.
    Jan 2005
    SoCal
    Try "normalizing" it first by laying it on a flat surface and SLOWLY heating it to about 180-200f. Then SLOWLY let it cool down.
    The high speed, typically used in extrusions, leaves a lot of built-in stress.
    hth,
    Pres
    Jun 2007
    I will have to work on that pres. Finding a heat source large enough to do that might take me some time.
    Thanks for the suggestion.
    Keep them rolling in.
    Paul
    1. Dynatorch opinions... routering?
      By Scratch in forum DynaTorch
      Last Post: 05-05-2006, 07:30 PM
    2. Routering sheet PolyPropylene
      By planeflier in forum General Material Machining Solutions
      Last Post: 05-01-2006, 11:10 AM
    3. Help with selector switch wiring issue (***actually a motor issue***)
      By BEDFORD in forum Industrial Hobbies (Support forum)
      Last Post: 04-07-2006, 04:19 PM
    4. NEWBIE!!! Confused with 3d Routering and Milling
      By Sanghera in forum General CAM Discussion
      Last Post: 04-19-2004, 10:58 PM
    5. Fonts for Routering & Engraving
      By DaSigntist in forum General CAM Discussion
      Last Post: 12-29-2003, 11:12 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
