Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 01-31-2008, 09:49 AM
settle is on a distinguished road
accurate cardboard cutting?
hello
i have just started looking at cnc machining and i'm after some advice.
Basically i want to cut 2mm thick cardboard, from roughly 200-300mm square sheets, accurately and with out leaving marks on the cardboard.
I would be using it to create models from a autocad.
I have prevously used a laser cutter but as it leaves a slight burn it isn't really ideal.
I've looked through the forums and people mainly machine wood, plastic and metal, all general stronger, on cnc mills, would it be possible to cut card or would it tear out because of the short fibre lengh?
Any help or suggestions for a 'buget' machine would be very helpful
Hopefully this is in the correct forum, if not please move!
R2E3 not accurate cut more Bridgeport and Hardinge Mills 3 10-03-2007 11:25 AM
What is more accurate CNCadmin DIY-CNC Router Table Machines 12 06-07-2007 05:49 PM
What is the most accurate CNC? cooler21 Commercial CNC Wood Routers 16 03-25-2007 07:27 AM
What method will be more accurate? DennisCNC Mechanical Calculations/Engineering Design 9 09-01-2006 05:44 PM
How accurate? bearwen JGRO Router Table Design 9 02-19-2006 08:07 AM
