Results 1 to 6 of 6
Thread: Routing Aluminum as fast as I can?
    Oct 2007
    Question Routing Aluminum as fast as I can?
    I got a rush job to do milling ¼" aluminum with an ¼" O flute Onsrud
    I have coolant ready and don't have time to make any mistakes.
    I was thinking of cutting 0.1" per pass..not sure of the speed.
    Any advice would be great..thanks
    Gerald
    Registered neilw20's Avatar
    Jun 2007
    Cool
    Quote Originally Posted by Imperium View Post
    Gerald
    Depth not exceeding half the cutter diameter. 0.1" sounds good.
    If it is good quality aluminum the it will be a soda.
    If it is saucepan aluminium watch for cutter cloging like a hawk!.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Oct 2007
    Soda.as in crackers? lol
    I'm not sure what "soda" means
    How fast could I go at 0.1" ..40ipm 70? I don't know
    Last time I posted my feed speeds were way too slow.
    Cheers
    G
    Mar 2003
    Shelby Twp, MI....USA
    Oct 2007
    Thanks Gerry,
    I wish the onsrud guy would have told me about that page.
    Because I'm somewhat of a CNC newbie, how does chipload apply to depth of cut?
    Thanks again,
    Gerald
    Mar 2003
    Look at the top right on that page and it tells you.
    1. How fast is this?
      By jmytyk in forum DIY CNC Router Table Machines
      Last Post: 02-07-2009, 06:41 AM
    2. Circuit Board on aluminum routing ?
      By electronrx in forum General Material Machining Solutions
      Last Post: 04-23-2006, 11:58 AM
    3. RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED -
      By JavaDog in forum Employment Opportunity
      Last Post: 11-17-2005, 03:25 PM
    4. Observations on Routing Aluminum
      By musicmkr in forum DIY CNC Router Table Machines
      Last Post: 09-14-2005, 11:59 AM
    5. Do you have a fast DSL? Help!
      By ESjaavik in forum CNCzone Club House
      Last Post: 08-18-2004, 10:25 AM
