Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 07-20-2007, 09:11 PM
rigo430's Avatar
rigo430 is on a distinguished road
High Density Urethane Foam (A.K.A. Butter-board)
I need to know some good suppliers of high density urethane foam that I can use for making mock up parts and models I've designed in CAD. Does anyone know where's a good place to get some for a good price?
Old 07-21-2007, 01:55 AM
Laff Riot is on a distinguished road
HDU is a staple product for signshops. We use it instead of wood for sandblasted and routed signs.
Chances are you have at least two sign shop suppliers that deliver to your local area weekly. Do a search in your online yellow pages - and make sure you are looking in a large enough area - my supplier delivers twice a week and is a 2 hr drive - they roam!
They will be selling it under trade names like Design Board, Sign Foam, Dura Board - etc. Also ask them if they can recommend a sandblaster - they will have a ton of scrap they will sell cheap! Use Gorilla glue to mock up larger pieces as needed.
Idea of prices.
4x8 Sheets - 3/4" $157., 1" $196., 2" $326., 3" $500.
Another note - I prefer using PVC sheets sold under the name brand komatex, sintra - It takes less damage, keeps sharper corners and is flexible enough that we use the 3/4 for 1-off molds.
4x8 Sheets - 1/8" $25., 1/4" $47., 1/2" $99, 3/4" 125 - much cheaper and more usefull
Worry about success, failure takes care of itself.
Old 09-10-2010, 01:06 PM
RayDaug is on a distinguished road
Craft Board HDU
24" x 48" x 1.5" Craft Board HDU $148.50
http://www.duracaps.com/product_info...roducts_id/134
Where to buy high density foam? WarrenW General Material Machining Solutions 4 11-07-2006 01:06 AM
High Speed CMS FOAM 5-axis milling machine fairlane77089 Hard and High Speed Machining 4 06-05-2006 10:09 AM
Urethane Resin Casting: Linear Glides & Leadscrew Nuts scratch_6057 DIY-CNC Router Table Machines 2 03-26-2006 01:13 PM
high-density polyethylene MBG General Metalwork Discussion 7 09-13-2005 07:31 AM
High amp driver board jimglass General Electronics Discussion 1 04-09-2003 08:46 PM
