Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 07-12-2007, 07:16 PM
DrStein99's Avatar
DrStein99 is on a distinguished road
Polishing and painting questions from newbie
I have a home-build CNC milling machine, I use to cut decorations from 1/8 aluminum flats. They come out very nice with the machine.
So, its basically an inlaid piece of artwork.
Ok so to make it look really nice, I normally sand with 250 grit, then 400 and then scotchbrite, then I use a rotary tool w/ trippoli compound around the raised edges. This makes it mirror-like.
Then I would proceed to use a small paintbrush and paint the inlays using laquer paint.
It seems EVERY time I paint something there are specs of DUST in it. Is there a paint or process or something I can do to paint something and NOT have dust-specs?
Also - is there anything I can do to automate, or get the polishing process down from hand-sanding?
ID:	40573   Click image for larger version
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 07-12-2007, 08:26 PM
rustamd is on a distinguished road
even if using expensive paint booth to paint part there are still chances of having dust specs
Do you paint first than polish or polish first?
Old 07-12-2007, 08:39 PM
DrStein99's Avatar
Thats what I thought - no matter HOW clean I make my area, there is always some dust; unless its a dustfree environment like the ones they use to assemble platters for hard-disk drives.
I know people paint little models all the time, and they never seem to have dust flecks in them so there must be a technique somehow.
Ideally I would like to find something I could just throw down as a powder or paste and MELT it in the oven on low heat-set. I think thats a good idea but dont know where to start.
I tried both methods- polish first, then paint. And paint first then polish. I have found its much easier to clean away accidental paint off a polished finish, then it is to recover a painted surface from accidental sanding or a hit with a rotary tool.
So for now, I polish FIRST then paint - but I am very open to advice and suggestions.
I also have a small viabratory tumbler, the cheap little $40 at harbor freight. I have a mix of tripoli compound and walnut shells. This seems to work over time say two days, but I am not sure its supposed to work with flat parts that are 4.5" wide.
Newbie Questions... BryanDowdy CNC Plasma and Waterjet Machines 5 01-02-2007 01:42 PM
Newbie with questions wafarmer General Metal Working Machines 11 12-20-2006 06:30 PM
newbie questions seware74 PicStep Controllers 0 01-11-2006 10:44 PM
Newbie and some questions..... skymaster DIY-CNC Router Table Machines 2 09-12-2004 05:11 PM
Newbie questions NeoMiller General CAM Discussion 7 11-08-2003 07:39 PM
