Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-19-2007, 04:26 PM
deleteallusers is on a distinguished road
Defective SGS products.
SGS 1/64 Carbide End Mill - PN# 30191
I bought one of these to day, and could not even sit it down flat on
the PCB. It snaped without even putting a mark on the board, and under
praticly no pressure, it cost me $23.00, and they said that I must have abused it because it broke.
What’s up with these things, I need to mill tight traces on a PCB, and it looks like this is the only thing I can use to go that thin.
Any advise ?
Thanks,
Old 06-20-2007, 08:45 AM
RayinNH's Avatar
RayinNH is on a distinguished road
I don't know why the SGS one broke, I have never used miniature endmills from them. A couple other options for miniature carbide tools are www.harveytool.com, or www.robbjack.com. I order both brands from MSC Industrial Supply, www.mscdirect.com. The MSC part # for a Robbjack .015 EM is 04468567.
Old 06-20-2007, 09:28 AM
Thanks for the advise, I need small end mills so I can continue my project.
I'm new to this, and really don't know what to use.
I really beleve there was somthing wrong with the SGS, I know these are fragle but this one really broke way to easy.
I'm trying to mill PCB's that have small traces on them, and I need
an end mill that will hold up and not snap. (As much as possiable)
Thanks again.
Old 06-20-2007, 11:11 AM
msomerville is on a distinguished road
Harvey tool makes a couple of different endmills just for plastics both abrasive and non.
Old 06-20-2007, 03:12 PM
Gold Member
Mariss Freimanis is on a distinguished road
I can't say about carbide 0.0156" endmills but I can about 0.0156" carbide drill bits. They snap in half if you even look at them cross-eyed. They are extremely fragile parts that will break with only an ounce or so of side-load.
Mariss
Old 06-20-2007, 03:22 PM
samco is on a distinguished road
I have had great luck with these.
http://www.thinktink.com/cgi-bin/car...tep=20&start=0
1/16 diam.
I oopsed it and did a rapid thru the circuit board.. Just cut a nice slot. at around 20Krpm and 100ipm.
sam
Old 06-20-2007, 03:29 PM
Oh - picture
http://www.electronicsam.com/images/...ostart/top.JPG
sam
Old 06-20-2007, 04:07 PM
Red face
@samco,
Looks like you really have a nice CNC machine, mine is DIY.
What kind of machine do you have ?
Do you have sensors on the pressure foot, that feedback to
your software and autoadjust the depth of the cut ?
I would like to do somthing like that, but I dont have sensor feedback,
You can almost see through the board and read the computer screen.
@Mariss
The 0.015 ball endmill I used before was acutaly pretty tough,
but they all seem to break in the same place and snap completly off,
I have now purchased a few Robbjack SS-2-015 STUB length 2 flute
end mills, I hope they hold up as I set them down on the board.
I must set Z depth manualy as I dont have any sensors.
I'm using real thin copper stock, it seems like it should push through the
material before it would break, the material is FR4 - 014 THK PCB
Thanks,
Old 06-20-2007, 04:14 PM
ah - no.. The machine is a limp noodle. <- technical term. But it does ok. I am using emc2 and have a touch off switch for setting tool length.
http://www.electronicsam.com/images/KandT/DSCgantry.JPG
It gets the job done.. I would love to get a smaller micromill or such to do my circuit boards.. being able to cut into the 20ipm range would be nice.
sam
Old 06-20-2007, 04:29 PM
Wow, I wish I could get results like that.
I think I need to try that touch off switch idea.
I'm also thinking about a simple vacuum setup for holding my material.
  #11   Ban this user!
Old 06-20-2007, 04:31 PM
I should say - I use the 1/16 end mills for clearing and Mechanical etch bit (0.0625" carbide spiral flute, 60 degree triangle tip
cutter) from the same company for isolation milling.
sam
  #12   Ban this user!
Old 06-20-2007, 04:41 PM
Red face
Ua... How do I setup a touch off switch ??
Is it hard, I can figure out how to setup my software,
but... how do I do the switch ?
Thanks much for all the help, I think I'm getting closer to success.
I need to... my boss is starting to show his fangs...
Update: I can't really find anything specific on a touch off switch setup.
Could someone advise me on adding this feature ?
Thanks,
Defective stepper or driver shadesdude Stepper Motors and Drives 2 02-14-2007 11:41 PM
Defective toroidal? JMValios General Electronics Discussion 3 12-15-2005 04:45 PM
Donate your defective G201. creative_mind Gecko Drives 12 02-12-2005 02:08 PM
