Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 05-23-2007, 03:30 PM
MagTDK is on a distinguished road
Can you bead blast plastic?
Can you bead Blast plastic without deforming the surface?
I would like to remove some machine marks left over on the plastic from cutting it with a CNC machine. I could sand it but I'm looking for a quicker way if possible. And I'm asking because I don't own a bead blast cabinet or gun to test it, and I'd hate to invest in one just to find out it won't work.
Old 05-23-2007, 04:12 PM
gonejunking is on a distinguished road
I don't think it'll work as you hope. I've blasted plastic with glass beads, it removed paint and rubber marks, but left the machining marks. You could try sand, but it would inbed itself into the plastic and possibly eat thru your mat'l.
Get out the sand paper.
Just my 2c worth
Old 05-25-2007, 12:15 PM
Thanks for your insight. I guess I'll stick with sand paper for now.
Old 07-21-2007, 02:15 AM
Laff Riot is on a distinguished road
Call a local plastic supplier / finisher for the correct blowtorch & gas recommendation. We called piedmont plastics and they sent out a rep with a portable unit to show us how to speed up. He bought his kit at home depot - I remember it had to be a high oxygen flame.
He cleared the edges as fast as he could move the torch - but - he had a lot of experience. It also works better with either cast or extruded acrylic but I dont remember which. If you look into it let me know.
For minimal production - scrape the edge with an x-acto knife - its not crystal clear but its definetly faster than hand sanding.
Worry about success, failure takes care of itself.
Old 07-21-2007, 08:53 AM
Gold Member
InspirationTool is on a distinguished road
I just had some Delrin parts cut with a laser. They were vibratory finished afterwards, and that removed the swirl marks.
-Jeff
www.JeffAlbro.net/cnc/
Old 08-03-2007, 08:02 AM
68rustang is on a distinguished road
What type of plastic?
Like Laff Riot we "flame polish" our acrylic using a torch with a real fine tip flame. The end result is crystal clear.
-Eric
Alibre Design Expert , SheetCAM, Tormach PCNC-1100, Techno-Isel RG-5996.
mazak air blast rhurt Mazak, Mitsubishi, Mazatrol 1 03-05-2007 09:34 AM
Air blast thru spindle ajl6549 Mazak, Mitsubishi, Mazatrol 5 02-09-2007 06:13 AM
Convert your router to cut vinyl and sand blast as well. ynneb Printing, Scanners, Vinyl cutting and Plotters 17 01-11-2007 09:09 PM
Bead blasting on a budget MrRage General Metalwork Discussion 9 09-07-2005 03:59 PM
Sand/Bead Blaster wood cutting DDM DIY-CNC Router Table Machines 13 12-27-2004 08:12 AM
