Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-27-2007, 08:39 PM
zaheerabbas97 is on a distinguished road
Question advantages of upmilling on Aluminium material
hi,
iam newbie to cnc i would like to advantages of upmilling using a coated carbide cutter. and what if using down milling. as i asked to my senior just he avoided to answer
thanks for your usefull suggestions
Old 03-27-2007, 10:50 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Climb milling will typically leave a better finish.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 03-27-2007, 10:59 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
climb milling the cutter pulls the chip away from the work piece ,conventional milling pushes the chip into the work piece
Old 03-27-2007, 11:07 PM
psychomill is on a distinguished road
Also, in the past... a solid carbide endmill didn't like the extra "shock" (so to speak) of conventional cuts. It's really noticeable when you started feeding real heavy.... the tips would chip or break... if not the whole endmill snapping. Many tools are tougher today though. But its good practice (with better and "expected" results) to climb cut.
It's just a part..... cutter still goes round and round....
Old 04-01-2007, 03:14 PM
Madclicker is on a distinguished road
I'm confused, but I was born that way. The link below seems to say the opposite and is the way I always thought it was.
http://www.hanita.com/hanita_protected/tec00006.htm
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 04-01-2007, 03:46 PM
dertsap's Avatar
Gold Member
i dont think your link shows the opposite ?
if the chip is being pulled thru the work piece it will leave the chip behind as your link shows , if it is pushing the chip it will leave the chip in front of the path which is also stated in the link
climb milling always has a pulling force where as conventional is the opposite
when lets say a part wasn t tightened correctly and the part comes out :
conventional will push the part away from the cutter most times with minimal damage to the tool and part (if your lucky),
climbing will pull the part into the tool throwing the part with a higher chance of damage to the part and tool
Old 04-01-2007, 04:05 PM
I'm confused .
I thought 'conventional cuts' were up milling where the cutting edge enters the workpiece gradually; so where does the "shock" come from?
Old 04-01-2007, 05:27 PM
I guess it just depends on how you describe how the chip is being "pulled". I would describe it the other way around.
Steve
Old 04-01-2007, 08:17 PM
dertsap's Avatar
Gold Member
probably why i m not a teacher ,that and my low patience level
Old 04-02-2007, 05:23 AM
joecnc1234 is on a distinguished road
In cnc milling a climb cut is always better. The spindle pulls the part towards it. The load is less and tool life is better. Try it on a conventional mill climb mill and it pulls the table conventional cut and you have to force the movement. The shock comes from the flutes banging against the workpiece. Your drawing demonstrates the tool movement but invariably some of the chips won't clear then you recut them and wear the tool faster. with the rigidity of most cnc's climb cutting will put the chip behind the cutter to be blown away by the coolant spray.
  #11   Ban this user!
Old 04-02-2007, 07:16 AM
HIRAH is on a distinguished road
i usually climb mill. but there are certain times that conventional milling has an advantage. and to me that is cutting a flame cut edge. when you conventional mill, the cutter is starting from the inside of the flame cut and breaking off the chip, rather than cutting into the harder flamecut.
  #12   Ban this user!
Old 04-03-2007, 02:30 AM
I agree with you hirah that would defiantly be a case for climb cutting.
Advantages of 3 Phase Step motors bunalmis Stepper Motors and Drives 11 05-23-2006 04:45 PM
Aluminium in Auckland triag Australia, New Zealand Club house 2 12-14-2005 03:57 PM
advantages of using nitrogen? anthony CNC Plasma and Waterjet Machines 8 12-05-2005 10:04 AM
Advantages and disadvantages of CAM Saftwares gopinb General CAM Discussion 5 05-15-2005 10:16 AM
Stepper Increment Advantages CNCadmin General Metal Working Machines 2 03-09-2004 08:36 PM
