Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-07-2007, 10:51 PM
big_mak is on a distinguished road
Alumina Composite
Any one have any experience with Alumina Composite in regards to milling?
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 03-07-2007, 11:11 PM
I did a Google search and found this: http://www.zrci.com/zrci001.pdf
Supposedly it can be machined with carbide tooling. I would expect tool life might be short and I am not sure I would want the dust getting into my machines. Here is a description stolen from a different website:
"Any of several forms of aluminum oxide, Al2O3, occurring naturally as corundum, in a hydrated form in bauxite, and with various impurities as ruby, sapphire, and emery, used in aluminum production and in abrasives, refractories, ceramics, and electrical insulation. Also called aluminum oxide."
The idea of filling my machine with an abrasive dust doesn't turn me on.
Old 03-07-2007, 11:15 PM
I already thought about having dual shop vac's set up as dust collectors.
The Zrci was the page that I got my info from. Tey state RPM, but no cutter dia, so you can't even work out SFM!!!!!!!
Old 03-14-2007, 01:25 PM
fer_mayrl is on a distinguished road
Alumina composites are the same as solid surface materials. (corian)
It is very easy to cut, maybe like a hard wood. if you have a high speed spindle, you can cut it at 20000rpm, with a 1/4" or 3/8" carbide endmil, (use only corbide) you could go at least at 100ipm if your machine permits, at a 1/2"DOC.
Look for solid surface fabrication manuals, you might find what you need.
Routing Dibond composite GVP General Material Machining Solutions 3 02-27-2010 02:11 AM
Composite dry sliding bushings... How good are they? Brunow Linear and Rotary Motion 9 01-17-2007 05:04 PM
Looking for some composite routing Locster13 DIY-CNC Router Table Machines 3 11-02-2006 10:20 AM
Larger Surfboard Blank foam Composite Plug cutter Latexgurl CNC Wire Foam Cutter Machines 3 07-12-2005 12:49 PM
Help Sw 2004 (composite Curves) CAMCRASH Solidworks 3 04-30-2005 09:45 PM
