| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Hi, I want to turn a servo motor shaft to a smaller diameter to fit a planetary gear setup? I thought about clamping the motor in the jaw, apply voltage to the motor so the shaft turns, then machine the shaft to smaller diameter. Anyone tried this already? David |
| Id be worried about putting too much pressure on the motors bearings from the cutting.. perhaps running it and then running a grinder on the shaft.. set it up right and shield the motor from the dust and it should work OK.. ~Steve |
| I'm not a machinist I'm afraid, but you may like to look at Arie's posts on the zone. Post #45 of this... http://www.cnczone.com/forums/showth...highlight=arie ...shows how he machined the shaft of his spindle. It is an awesome thread. Best wishes Martin |
| Sure, you can do it. I just connected a battery to my dc servo and reduced the shaft from 6mm to 5mm for encoders. Granted that is a fairly small amount, any more than that I would probably use a different method. I used a file and thin strips of sandpaper. I took my time and periodically checked the shaft diameter at several locations. It doesnt take much pressure, I was more concerned about getting dust in the bearings. I did two motors, and they came out really nice. |
| Turning smaller diameter delrin? | conceptmachinin | General Material Machining Solutions | 29 | 03-08-2007 02:02 PM |
| DIY Large Bore Hollow-shaft servo motor | Eric R. | Linear and Rotary Motion | 9 | 01-27-2007 08:19 AM |
| Hollow Shaft Servo Motor | Eric R. | Open Source CNC Machine Designs | 2 | 01-11-2007 01:01 PM |
| Drawing shaft diameter 8h7 (metric) ??? | Argofanatic | General Metalwork Discussion | 7 | 12-27-2006 08:42 AM |
| Diameter of shaft for linear-guide | Phantom | DIY-CNC Router Table Machines | 7 | 10-26-2005 10:11 AM |
