Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 11-21-2006, 03:43 PM
star1280 is on a distinguished road
milling magnets
Can this be done? Does it ruin the polarity? What type of tooling do you use? Does it matter if its permanant or rare earth? I'm assuming grinding is the way to go but I dont have a grinder....
Alicia
Old 11-21-2006, 06:28 PM
NC Cams is on a distinguished road
Four words:
DIAMOND ABRASIVE GRINDING WHEELS.
At least, you're trying to cut ceramic fired materials.
When you cut a magnet in half, you end up taking a N S pole device and turning it into a N S and N S device.
THus, you can "ruin" the polarity.
Better yet, get them uncharged, cut them then magnetize them. You should be albe to "set" the polarity when you do it that way, depeding on how the magnet structure is oriented.
Old 11-21-2006, 06:52 PM
Alicia
If it is a ceramic magnet and not too thick you might be able to score it and break it much like with ceramic tiles. You will never mill ceramic magnets they are approximately as hard as your cutting tools.
Old 11-22-2006, 07:54 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I have always found milling or turning "rare earth" or Alnico magnets very simple. They are very soft. You want to cut them hard and heavy and keep the chips from away.
Any tooling will do.
Ceramics, on the other hand, I know better than to try and cut them.
www.integratedmechanical.ca
Old 11-22-2006, 11:14 AM
thanks guys!!! I'll let you know if we go through with it.
