Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 07-31-2006, 02:09 PM
jimcobalt is on a distinguished road
Problem milling MDF.
I am a newbe with a tabletop CNC router table which uses a Rotozip.
When cutting MDF with a new 1/4 inch two flute carbide end mill, the edges of the material are left rough and frayed. Depth: 0.10, Feed: 60 ipm, RPM: 15m.
I am producing molds for casting urethane rubber which will be used to cast plastics.
Any suggestions on other inexpensive milling substrates would be appreciated.
Thanks, Jim
Old 07-31-2006, 02:28 PM
Jarwalcot's Avatar
Jarwalcot is on a distinguished road
Jim,
This was posted awhile back.. See if it helps.
Good luck,
JR Walcott
Georgia Machine Tool Resources, LLC
Old 07-31-2006, 03:13 PM
JR
Many thanks for the speed rate guide. Based on this, my rpm is set too high. I will make the adjustment and run a test.
Regards, Jim
