Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-19-2006, 07:19 PM
xovationx is on a distinguished road
material to practice milling
hi,
im new to milling and before purchasing any actual aluminum to machine with wanted to hopefully practice with some sort of cheaper material. from what i can tell foam will probably be my best bet. if anyone has any suggestions on some practice materials i could use them. also...if it is foam what density will be the best for me to practice with? as i understand the higher the density the higher the cost, so what would be a good balance between the two that would let me mill something decently close looking to an aluminum piece?
oh...this is just manual milling by the way...no cnc yet.
thanks for any help
-rene
Old 03-19-2006, 07:32 PM
*Registered*
lakeside is on a distinguished road
I Bet If You Go To The Local Land Fill And Look In The Recycling Area You Could Find A Piece Of Alum. For Free
Old 03-19-2006, 07:45 PM
wow....i almost feel dumb for not thinking of that first...
Old 03-19-2006, 08:03 PM
sanddrag is on a distinguished road
Aluminum is somewhat expensive, but most plastics are even more expensive and some foams aren't cheap either. Also, to get a good idea for feeds and speeds and surface finish or whatnot, I'd recommend getting used to the machine with some real material.
Old 03-19-2006, 08:14 PM
alright...thanks for the input guys...ill head over to the local recycling dump and see what i can find to practice with.
Old 03-19-2006, 08:26 PM
JohnnyYuma is on a distinguished road
if your really into "do it yourself" you could make melt and repour the Waste alum that way you get scrap Alum and make it in to useable sizes, I seem to remember runing acrossed a site on how to make a furnace using a metal 5 gall. bucket and fire block of some kind
JohnnyYuma
Old 03-19-2006, 08:27 PM
Auto shops are a good source for Alum, always have Pistons to Throw away
JohnnyYuma
Old 03-19-2006, 08:40 PM
*Registered*
Well That Would Not Be A Much Fun As Trying To Melt Alum. In A Bucket
Old 03-19-2006, 09:33 PM
ZipSnipe is on a distinguished road
Look for a scrap surplus place in your town or salvage yard, they usually don,t advertise but they are a wealth of source.
Old 03-21-2006, 08:42 AM
Rustybolt is on a distinguished road
Try a piece of wood first. understand that metal won't chip out, but wood will give you an idea of what you're capable of and any tool crashes in the material won't be damaging.
Old 03-21-2006, 09:54 AM
svenakela is on a distinguished road
Yes, wood is very good for testing. Go for it.
