DOM (drawn over mandrel - if thats what we're talking about) steel will be somewhat stronger than galvanized pipe if the two are of the same dimensions. Gal. Pipe usually has a bigger cross section than DOM of the same size so there's more material in the pipe and so the pipe can be stronger. All depends on the dimensions of the part, then the material..
LinkBack URL
About LinkBacks
