Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 09-21-2003, 08:07 PM
Matt B is on a distinguished road
Anyone cutting carpeting or tile?
This may be a strange question, but anyone cutting low pile carpeting or vinyl tile?
We're shopbot users, and would like to know if anyone is using a router to cut carpeting or tile.
I can imagine a couple of potential disasters with both - melting fibers, melting/shattering vinyl...
If possible, any recommended cutters?
Thanks!
Matt
Old 12-26-2005, 08:52 PM
Kevin Taylor is on a distinguished road
I must ask why? I bought 100 utility knife blades for $13.00 at home depot but a waterjet might work on the vinyl but the carpet you might havetoo shampo afterwords!!! good luck Kevin PS just thought of something maybe a verson of hot wire cutting might work it works on nylon and kelvar but the natral fiber's like jutback capet maybe not .
Old 12-26-2005, 11:21 PM
Cutting tile may be possible using a down spiral cutter to prevent the tile lifting but I think you would have to use a slow speed to prevent melting.
Cutting carpet might be fun; have you ever drilled through carpet and had the fibers wind tightly around your drill bit as if it was a little winch drum? AND in the process pull a thread out of about ten feet of nice expensive carpet so all the pile fibers come loose.
I have this picture in my mind of your shopbot waving a tattered mass of carpet around itself like some demented cheerleader. Go ahead DO IT but promise to take pictures.
Old 12-27-2005, 12:49 AM
alt.don is on a distinguished road
For carpet I'd probably go with something along the vinyl graphic cutters. mount a heavier duty circular blade that rolls along and cuts the carpet into the spindle with it powered off and hope for the best.
Old 12-27-2005, 11:27 AM
Cut the tiles over a year ago, but thanks!
Thanks to each of you for responding to a thread that I most certainly thought was dead. Your recommendations, both serious and humorous, are greatly appreciated.
The carpet tile that I was considering cutting was a felted material, which machined quite nicely at a slow speed (-10K rpm) and did not melt - the linoleum tiles had a tendency to shatter along the edges -they were not jute backed, which made it a bit easier cutting with an o flute.
Thanks!
Matt B.
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
Cutting metal signIT DIY-CNC Router Table Machines 2 02-19-2005 11:14 PM
CNC router deflection calcs and cutting loads? Linus DIY-CNC Router Table Machines 1 09-10-2004 10:08 AM
Do you account for climb cutting in G code? fyffe555 DIY-CNC Router Table Machines 12 11-06-2003 07:21 PM
Anyone Cutting Carpet of Vinyl Tile? Matt B DIY-CNC Router Table Machines 3 09-29-2003 10:37 AM
