Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 11-20-2011, 01:26 PM
ironofeden is on a distinguished road
machining 80mm deep
hi does anyone have tactics for machining aluminium 6082, profile 80mm deep?
having trouble with the finish
regards
benjamin
Old 11-21-2011, 04:50 PM
Moderator
ckelloug is on a distinguished road
Thoughts:
80 mm is way more than you can do in one pass but you already knew that.
If you're having surface finish issues, how rigid is your setup?
Are you using carbide or hss? Carbide is stiffer but it does require
the setup on the machine to be more rigid. Larger diameter cutters
are more rigid than small ones.
Are you using reasonable speeds and feed for the cutters in use?
A 1/4 inch carbide cutter needs higher speed for optimum cutting than a Bridgeport style machine can provide.
machining a small deep slot Richl General Material Machining Solutions 5 09-24-2011 09:25 AM
80mm Spindle Mount Sources? Zuni DIY-CNC Router Table Machines 2 04-05-2011 06:00 PM
Problem- Seeking Advice - Deep Bore Machining & Finishing ugleprasad General Material Machining Solutions 2 12-25-2009 09:25 PM
Machining Deep Profiles Babba Syil Products 2 07-19-2008 11:35 PM
80mm and 60mm MPGs now in Stock phomann Product Announcements & Manufacturer News 1 02-13-2008 11:21 PM
