Results 1 to 8 of 8
Thread: How would YOU machine this part?
    Nov 2011
    Post How would YOU machine this part?
    Hello. This is my first time posting in a forum, and I hope that I have posted this question in the correct one.
    As per the request of my employer, I am going to ask a very vague question. How would YOU go about machining this mechanical rosette?
    Currently, the company only has a 3-axis mill which we use to create prototypes. We essentially want to know if there is some way we can machine this mechanical rosette using our mill. Please see attachments. Dimensions included.
    Note: Material is stainless steel.
    Attached Thumbnails Attached Thumbnails How would YOU machine this part?-rosette_d14.pdf   How would YOU machine this part?-rosette_d14_2.jpg
    Oct 2011
    First off, you're short at least three critical dimensions.
    The angle of the notch for each v, the number of v-notches and whether or not the bottom of the notch is perpendicular to the axis.
    That last is the important dimension. the 8.68 degree slope is going to be a fuction of the angle of the v-notch, the path of the bottom of the v and the number of teeth in your rosette.
    Assuming that the v-notch is a 60 degree angle, one could either mill it with a 60 degree cutter or with a shaper and a 60 degree cutter.
    If a 90 degree notch can be used, I would set the part on a rotary table, angle the table 45 degrees, then make the cuts one at a time with a standard end mill, rotating the table between cuts.
    If the bottom of the v-notch is not parallel to the back surface, the rotary table would have to be angled an appropriate amount around the z axis as well.
    Jim Hurlburt
    Yakima, WA
    Jan 2010
    1. A dividing head with a mandrel to mount the blank
    2. Mount the dividing head to the table, with the longitudinal center line at the angle needed.
    3.Use this type of mill cutter; HSS 60° Double Angle Cutters
    4. Set the center of the angles on the cutter, with the center line of the part/dividing head.
    5.Cut from outside edge into center and back out again(free pass going out)
    6. Index to next cut and repeat till done.
    Oct 2009
    This is a compound angle .
    KISS , way.
    tip and turn "SIGN PLATE" the part.
    your leading angle will be of course deeper in the back or outer edge.
    your cutter will have to be a " \| " wheel like cutter.
    the angle of the cutter is a certain angle and not the angle of the cut.
    Hint :
    the cut will cut the deeper side first.
    No I did not read packrat post before I wrote this.
    I still like to grind this part, If you get what I mean.
    I use to work in a tool and die shop.
    I did alot of lead in work for strips.
    I almost got excited the first time I did one.
    the Grinding wheel hit high on the wheel before it hit low.
    Mar 2006
    Or just buy a Hirth coupling, which your picture appears to be. They're commercially mass produced and sold.
    Dick Z
    DZASTR
    Nov 2011
    Thumbs up
    In response to jimhurlbert,
    The angle of the v-notches are 58.71 degrees, there are a total of 36 notches, and the bottom of each notch is indeed perpendicular to the axis.
    Thank you all for your responses as they will all be of help. I am also glad that Richard Zastrow pointed out that this piece also goes by the name of a Hirth coupling. I will be looking into that today.
    Mar 2006
    Try "googling" Voith Hirth Couplings.
    Dick Z
    DZASTR
    Nov 2011
    Richard,
    I've taken a look into Voith and the company seems like they just may be able to supply something of use to us. I'm currently looking into obtaining a catalog. Thank you for the tips! They are very much appreciated.
    1. Need help trying to get rid of a machine, part out value??
      By mgb1974 in forum General Metal Working Machines
      Last Post: 06-04-2010, 11:50 AM
    2. how can I machine a part like this.
      By cob in forum General Metalwork Discussion
      Last Post: 08-13-2009, 01:24 AM
    3. CNC machine part 3
      By Foxbat in forum Rockcliff Machine
      Last Post: 03-07-2008, 11:41 AM
    4. CNC machine part 2
      Last Post: 01-31-2008, 07:48 PM
    5. Machine Down Need Part Bad!!!!!
      By joe1970 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 09-29-2005, 07:36 PM
