Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 11-15-2011, 01:09 PM
Rickylee53 is on a distinguished road
Machining alluminium
Hello,
I'm having problems with my end mills getting "clogged" on alluminium then the finish is poor.
I'm using a 3mm 4 flute carbide end mill at 3500rpm's. Using a feed rate of 60mm per minute, taking a 0.5mm cut with flood coolant.
The cutters were from here, i'm not sure if you can get an alluminium specific which is less likely to clog, or change the feed/speed
7LEADERS 2MM SOLID CARBIDE END MILL (E114F) TiALN NEW | eBay
Any suggestions?
Old 11-15-2011, 01:17 PM
WATERJET71's Avatar
WATERJET71 is on a distinguished road
use a 2 flut endmill
Old 11-15-2011, 01:22 PM
Will try that, is there any way to make my current cutters work? I've got lots of 4 flute end mills.
Old 11-15-2011, 02:49 PM
dblox is on a distinguished road
Three problems, the cutters are coated (uncoated would be much better for aluminium), too many flutes, and the feedrate is not high enough.
Try upping the feedrate to about 250mm / min.
At 60mm / min a four flute cutter is kind of friction welding its way through aluminium.
You need to make a big enough chip with each flute so that the coated cutter can actually take a scoop of metal away instead of rubbing, but not so big that the chip jams up in the flute.
Old 11-15-2011, 05:16 PM
Hello,
Thanks for your reply.
Thats interesting to know about coated, i'll try and save these cutters for steel then.
I didn't realise you could go "too slow" I didn't dare go that fast for fear of snapping the tool or wearing it out very quickly.
While i'll probably reserve these cutters for steel i'll also try a faster speed rate on the next ones.
Thanks again for your help.
Old 11-15-2011, 07:04 PM
TiAlN coated tools have a coating that is partly aluminum oxide, that is the Al part of the name. Using these cutters for aluminum is not successful because the aluminum oxide coating tends to stick to aluminum not allow the chip to slide past. Not even flood coolant can overcome this stickiness and if you try using these cutters on aluminum at high rpms on a big machine you get a smoking, steaming blob of metal spinning round.
Job Opening Machining Fixture Designer w/machining background - MI MachiningJobs Employment Opportunity 0 04-04-2011 04:53 PM
Need Help!- Alluminium engraving???? contour General Metalwork Discussion 7 05-12-2009 12:49 PM
deep drawing alluminium cob Vacuum forming, Thermoforming Etc 0 04-21-2009 12:21 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
