Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 08-01-2011, 08:28 AM
jdwhittaker is on a distinguished road
drilling small deep holes in 304 ss
We're drilling 7/64" diameter holes 1-3/4" deep in 304SS, and the drill is walking by as much as .02" on the exit side of the hole. We're using an M51CO drill from Precision. Drilling at 16.4SFM and .003IPR per their recommendation. we're clearing chips every .075". They recommended .3", but we were afraid of breaking drillbits.
Anybody have any suggestions to help us keep our holes on location?
Thank you,
Dave
Old 08-01-2011, 11:36 AM
john_100's Avatar
john_100 is on a distinguished road
Hi Dave,
not knowing what machine your using I could be wrong but
could you not use say 2 or 3 drill bits starting with a "stub" drill then a series of longer bits
Welcome to New Dormer Site
follow the machining solutions link
and download the drilling pdf (second one down )
the picture is from this pdf
John
Name:	dormer drills.jpg‎
Old 08-01-2011, 11:57 AM
keebler303 is on a distinguished road
A carbide drill bit is more rigid and should drift less.
A gun drill has a guide area just behind the cutting edges which rides in the drilled hole so that it is kept from wandering. Might want to look into that as well.
Deep Hole Gun Drilling
Matt
Old 08-01-2011, 12:05 PM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
Check out the Titex Drills if you have through coolant.
Its what I use and have had no problems.
Good Luck~!
Drilling deep holes in cast iron DruMor Haas Mills 5 09-30-2010 04:14 PM
Drilling deep 1/2" holes? lukaslouw General Metalwork Discussion 10 07-29-2008 09:08 PM
deep drilling small holes in aluminum Fremont Dave General Metalwork Discussion 13 11-25-2007 01:03 AM
deep drilling 2mm holes kesparate General Metal Working Machines 9 09-15-2007 11:57 PM
Drilling deep holes. HSM Joe Machine Problems, Solutions , Wireless DNC, serial port 7 05-13-2003 12:14 PM
