Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 07-16-2011, 08:30 PM
aaron p's Avatar
aaron p is on a distinguished road
Needing a sub for SAE 1117 steel
Anyone know of a good substitue for SAE 1117 steel? Have a print from the 60s that calls for it. Automotive transmission part.
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Old 07-17-2011, 02:23 AM
Superman's Avatar
Superman is on a distinguished road
Google it
link
Old 07-17-2011, 06:08 AM
mfgbydesign is on a distinguished road
www.matweb.com
1018 is virtually identical, 0.4% less manganese.
The manganese helps the material case harden, not sure why, but that process adds carbon to the surface leaving a tough core. If no case hardening no difference.
If the part is being heat treated you need to let them know what it is so they know what to do.
Old 07-17-2011, 07:47 AM
PixMan is on a distinguished road
Why would you need a substitute anyhow? The 1117 machines really nice and I don't have any problems getting it. In my area, it's Peterson Steel of Worcester MA who stocks a lot of it.
Needing Help!! Pklef Employment Opportunity 0 10-20-2010 02:13 PM
Needing Help Pklef Employment Opportunity 0 10-20-2010 02:06 PM
New Guy Needing a Little help here Shop_Smith_Popp WoodWorking 20 03-30-2009 12:46 PM
Needing help please Larry Myers G-Code Programing 4 10-04-2007 02:22 PM
New guy needing help please... studysession Welding, Brazing, Soldering, Sealing 17 01-12-2007 01:18 PM
