Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-06-2011, 02:27 AM
Unicab is on a distinguished road
Kerf
I am new to Plasma cutting and have recently installed a Burny Phantom control unit. I do not understand how to set the kerf or what it really is. Can anyone help?
Old 06-06-2011, 07:00 AM
jimcolt is on a distinguished road
Kerf is the width of the material that is lost in e cutting process. If you are talking about plasma cutting....the kerf will vary depending on the power level (amperage), the thickness of the material and the cut speed.
In the Burny control you can adjust the kerf compensation....in other words when you enter a kerf width...it will automatically shift the cutter path so that the finshed part ends up the correct size.
If you are using a post procesing software (CAM....or Nesting software)....this kerf compensation may be don before the part drawing file is imported into the Burny...if that is the case...then leave the kerf compensation in the Burny set to "0".
Jim Colt
Need FastCAM help! Kerf question Sperstad General CAM Discussion 3 11-09-2011 03:46 AM
Need Help!- kerf issue! Pure-Powder CNC Plasma and Waterjet Machines 4 06-03-2008 08:17 AM
Need Help!- Kerf settings Pure-Powder LazyCam 0 05-27-2008 09:05 AM
Newbie- Kerf on Foamworks GEFR CNC Wire Foam Cutter Machines 2 04-02-2008 02:56 AM
plasma kerf sluggo CNC Plasma and Waterjet Machines 8 03-12-2007 05:53 PM
