| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
i cannot find a good combination of feed and speed for my table. i am running nema 23's on 3 axis'. i am using a 1hp variable speed (16,000-35,000 RPM) bosch colt router with 1/4" collet. i took my passes down from .25 to .175 but i cannot seem to get a nice clean finish on the pocket walls of a piece of poplar i am milling. the bit i am using is a 1/4" x 2 inch amana solid carbide downcut spiral. if anyone has any suggestions theyd be greatly appreciated. |
i do not do much wood machining. . some observations . cutter 1/4 by 2" long flutes? at 16,000+ rpm . depth of cut .25 to .17 . a cutter that is long bends and vibrates easily. can you try a shorter cutter? . many times a roughing cutter can machine 95% and then do a tool change to take light finish cuts. . vibration of cutter and machine AND workpiece can cause bad finish. machining thin material can cause the workpiece to vibrate too. |
| New Machine Build- speed and feed | fogassa | Laser Engraving & Cutting Machines | 3 | 04-21-2010 05:39 PM |
| Need Help!- Help with Feed and Speed | sa6200 | General Jewelry Design Software | 1 | 11-20-2008 11:48 PM |
| Using G01 alongside G00 (slow feed rate woes) | inthezone | FeatureCAM CAD/CAM | 4 | 07-31-2007 10:36 PM |
| RPM/Feed Speed 4 Ali? | bigz1 | Engraving Machines | 0 | 05-20-2007 05:14 PM |
| feed and speed / sfm | citra | General Metalwork Discussion | 3 | 03-17-2006 10:55 AM |
