| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
I'm having trouble with a spiral milling tool path. the path spirals down a Z profile to form a taper on the desired material. the problem is that the tool path has to be created using CAM. the problem is that the parts are outside the allowable tolerance (+/- 0.01mm), and to alter this I have had to re-post the tool path after altering the tool diameter to compensate. is there any way to use cutter comp G-codes (G41, G42) to fine tune the program at the machine, rather than re-posting the program? |
| The taper is +0.003 above top tolerance. the machine doesn't have the G51 scaling command. I know G41 would work for one level, but as soon as a block containing X Y and Z moves is read the G41 will cause the program to alarm out. |
| If the taper angle is constant over the entire profile, or follows simple enough mathematical rules, it is conceivable to write a parametric program - ie you could put the profile into a loop and increment your tool offsets by the required amount for each pass. I have successfully implemented this approach to put chamfers/tapers on jobs using a ballnose cutter if I didn't have a suitable form tool. DP |
| Need Help!- Spiral Milling | NickDP | G-Code Programing | 7 | 09-27-2011 10:30 PM |
| Help Needed: Lathe live tool milling Cutter comp. | joseph10s | Hyundai Kia machine | 0 | 03-29-2011 09:08 PM |
| Need Help!- Spiral Milling | jlavery | Fanuc | 2 | 06-30-2010 11:39 PM |
| Milling cutter comp | j44snk | Okuma | 6 | 01-14-2009 03:56 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
