Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 03-01-2011, 12:32 PM
LaysMachinist is on a distinguished road
Steel Ring Egg Shaped and Poor Finish
I am cutting a right of A36 steel apprx 37 OD 30 1/2 ID and 1 1/8 thick. We are using a Bullard 56" VTL. We are have troubles with two things. The first problem is with our jaws. We have a hydraulic jaw setup which squeezes the part into an egg shape. (only by several thousandths). We have started alignments manually now and it seems to help. But the major problem we cant seem to get rid of is our terrible surface finish. The part chatters so bad it leaves huge waves in the steel. Any help or advice would be appreciated.
Matt
Tags
chatter, egg shaped, machining steel, speeds and feeds, surface finish
Steel piston ring material 2005bully Mechanical Calculations/Engineering Design 18 08-22-2011 06:22 PM
BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar) zerodegreec Benchtop Machines 6 09-14-2010 03:01 AM
poor surface finish sinha_nsit CNC Tooling 3 02-16-2010 09:48 PM
Need Help!- Poor surface finish pmsmichelle Mastercam 2 02-05-2010 08:54 AM
Acme Rod - Oil Finish Steel GeeksGoneBad DIY-CNC Router Table Machines 3 10-10-2008 06:27 PM
