Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 02-27-2011, 03:17 AM
mattpatt is on a distinguished road
SUS304
Hi Guys,
Trying to machine some stainless 304 and having all sorts of issues.
I have to cut a chunk out of it at a depth of 16mm.
I'm having reasonable results with a 12mm 4F carbide endmill at 1250rpm, full depth, 1mm step over and 600mm/min feed rate.
I'm sure there's a better way.
I have a HSS 16mm router, but haven't used one so not sure what to do with it.
Can anyone advise. For your info I have a Haas VF2 10k spindle.
Old 02-27-2011, 06:28 PM
jamesu229 is on a distinguished road
HSM
If your are using a coated endmill, .5 mm stepover .25mm ipt 3000 rpm
watch what can be done with stainless at
YouTube - HIGH SPEED MACHINING(REALLY HIGH!!!)
