Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 02-26-2011, 09:44 PM
Heather is on a distinguished road
Need: non-conductive aluminum like material
I'd like to know what your opinions are on a material that is like aluminum (strength) but doesn't conduct electricity like aluminum does.
I have heard of Delrin, however the specs on this material is very similar to poly carbonate. It's not as strong as aluminum and bends too easily.
Perhaps someone here knows of a material that's cnc machinable yet has some of the characteristics of aluminum.
Old 02-26-2011, 10:38 PM
The closest you can get to the mechanical properties of aluminum but without conductivity are some of the glass fiber reinforced nylons or polycarbonates. However these are the absolute b***h to machine because the glass reinforcement is so abrasive. It is also difficult to get a good surface finish and the mechanical properties are not really very close to aluminum being something like one third or less for tensile strength and less than one third for stiffness.
Old 02-26-2011, 10:55 PM
chicksdigwagons is on a distinguished road
Depending on your needs, anodized aluminum is non-conductive on the surface layer. May be enough.
Just IN- Material for projects. Metal and Aluminum geoline4 Product Announcements & Manufacturer News 0 01-31-2009 08:00 AM
Casting material to use for aluminum parts that end up being welded. KyleH2 Casting Metals 3 07-23-2008 02:43 PM
Alternatives to precise soldering - conductive plastic? medved General Electronics Discussion 5 03-18-2006 09:00 PM
Sand blasting material for aluminum ngr1 General Metalwork Discussion 7 12-06-2004 04:37 PM
