| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
| Gerdy, that hole depth to diamter ratio is going to make it a bear no matter which way you go. I'd be tempted to go with the lathe just to get the hole horizontal to help the chips come out, sort of like horizontal mills clear chips better than verticals. You're either going to have to get with the tooling suppliers to find the magic drill to work or attack the hole from 2 sides. If it isn't a through hole, no joy for 2 sides. A drill with parabolic flutes will help on a hole that deep. Best, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| First the good. 303 is butter as far as stainless goes. The bad-you are drilling 32x the dia. of the drill. My 2 cents... 1)#2 C/D @60 SFM Z-.060 2)1/8 jobber drill as far as you can go 3)Taper L. drill @ 50-60 SFM as far as you can go 4)Aircraft drill @ 50 SFM to finish the hole. Do this on your mill. Turn down the rapid and the coolant pressure. Drill at @ 2.0 IPM down deep,.040-.050 per peck. PS: Break it off in your customer! Dan |
| Need Help!- drilling 3d | rolveram | Mastercam | 2 | 12-14-2010 07:56 PM |
| Need Help!- Spot Drilling/Center Drilling Steel 55 HRC | JWB_Machining | General Metalwork Discussion | 7 | 03-11-2009 01:35 PM |
| Where is a how to on drilling? | MrWild | Dolphin CADCAM | 7 | 02-15-2008 06:46 AM |
| drilling and drilling cycles tutorial | wmorre | General Metalwork Discussion | 0 | 10-18-2006 06:30 PM |
| PCB Drilling | drk | Carken Products (Deskam, DeskCNC etc) | 3 | 12-14-2004 08:27 AM |
